derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
oscarkk
May 09, 2022Tutor
I have the European version of the router and after testing it, I can basically determine the problem: the wireless region is changed to Australia, and the problem of random reboots occurs. If the region is Europe, the reboot problem does not occur. For your reference.
DannyLin
May 09, 2022Apprentice
Thanks. That is one thing that I also suspect.
Mine Rax120vw is made in Thailand and I’m in Taiwan. But my region has been set to America. There’s no way I can alter the region setting — don’t know why.
