derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
jcassady88
May 10, 2022Aspirant
Good morning... Did your router replacement to another model resolve your issue? I am receiving the constant reboots and wonder if I just swap a new unit or go to another product such as Linksys or TP Link. Well, during this message, my router decides to reboot, once again. Pray for me!!!!!
jmcorra
May 10, 2022Tutor
Good Morning. I received a replacement of the Netgear RAX12 and unfortunately I encountered the same problem with random reboots with the new router. I did notice that when I approached 30 attached current devices (utilized or idle, i.e. devices, IOT's, etc.) the random re-boots would trigger. I can't be sure but suspect this may be a trigger event. Regardless, I thought it was time to move on and I replaced my Netgear with a ASUS router one month ago and I've not encountered any random reboots with the ASUS device.
- jcassady88May 10, 2022Aspirant
Yeah, I fortunately "bit the bullet" and purchased a TP-Link AX6000 WIFI 6 (Archer 6000) router about 10 minutes ago (Amazon will have it here at my home between 5:00pm-10:00pm today, fingers crossed). NG decided that I had enough problems and will be sending me a replacement router. Once I receive it, look out store I purchased it from, it's coming back for a "Full Refund'!"
I have always used Netgear and am very sad to go, but got to say goodbye sometimes..... Farewell Netgear community, in a few hours, I will no longer be a part of this lovely community....
- doctorcitoMay 10, 2022Starjcassady88 same! I bought a RAX200 which honestly worked great, but I found find myself having nightmares of the support I received with the RAX120, so I've decided to return the RAX200. I honestly was not confident that if something went wrong with my new rax200, that I would receive proper support. So I've moved on to Asus. Farewell Netgear community. I'll still be on the lookout for a solution as I have a RAX120 that's currently a paperweight.
