derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Oct 21, 2022Guru - Experienced User
Thanks for the info.
ghristov wrote:
FW version - 1.2.8.40
SN first 3 chars - 6K0
Before RAX120, I used the same LAN cable and ISP modem with Tri-Band Linksys 8300 router without any issues.
The problem was with those false DoS attacks caused by the camera. The same camera was working OK with my previous router mentioned above.
ghristov
Oct 22, 2022Tutor
ISP - The Bonds SAM WiFi Router, P/N SAM-4F1F-TT-W-A1.
FURRYe38 wrote:Thanks for the info.
- ghristovOct 22, 2022Tutor
Today I have started again my test with multiple 4K YouTube videos using several 802.11n, 802.11ac and 802.11ax devices working on 2.4 GHz or 5 GHz band in parallel. Everything was stable for many hours until ... I connected an old 2.4GHz 802.11b/g laptop playing YouTube video and the router restarted itself. It is not only my security camera which is causing restarts. It seems that all my devices that use 802.11 b/g standard for streaming are restarting the router. I have multiple security cameras and one laptop using 802.11 b/g. I have a streaming doorbell as well, but it use 2.4 GHz 802.11n standard and it is working pretty stable.
Conclusion: Every time in my tests when I use 802.11 b/g device for streaming the router restarts itself. If I use 802.11n/ac/ax device, regardless on 2.4 GHz or 5GHz band, the router is perfectly stable. Will continue with my observations ...
- dude8370Oct 22, 2022StarFor what it's worth when i had my V2, i disconnected ALL devices and just had one firestick Max 4k (AX) and it would reboot (sometimes days without, sometimes 12 in a day type thing.) Tried my laptop (AC) with nothing else connected....same result. Tried switch SSID names as well to no avail.
- FURRYe38Oct 22, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.Try option #2...
Thanks for the info. WiFi on the ISP router is disabled from the very beginning. The RAX120 and ISP are connected LAN to LAN. I've already asked my provider to bridge the port, without any success. Will try to contact him again. Anyway, I've already tried option 3 - NG router in AP mode, but RAX120 is still restarting itself.
FURRYe38 wrote:Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
ghristov wrote:ISP - The Bonds SAM WiFi Router, P/N SAM-4F1F-TT-W-A1.
Try option #2 with the ISP modem if they can't get it bridged.
Couple of options,
