derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
DarrenM
Nov 22, 2022Sr. NETGEAR Moderator
Hello David
I have sent you a Pm.
Thanks
DarrenM
David22066
Nov 22, 2022Aspirant
What is a Pm?
- FURRYe38Nov 22, 2022Guru - Experienced User
Private message.
- sonoranscoutNov 23, 2022AspirantJust curious…is there a newer firmware available than 43RC?
- FURRYe38Nov 23, 2022Guru - Experienced User
Nope.
