derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 20, 2022Guru - Experienced User
Sent.
rax120v2user wrote:
Serial: 6JY...
Modem: Arris Surfboard SB6190
ISP: Spectrum
Please pm me the link to the beta firmware.Trying to work from home and constant reboots.
Thanks
rax120v2
Dec 21, 2022Aspirant
I am also experiencing the random reboot issue every few days, with 2.4GHz radio disabled.
May I get the beta FW to test it out? Serial starts with 6JY on Spectrum model ET2251 DOCSIS 3.1 via CAT8 cable.
