Simon95132
Dec 25, 2021Aspirant
RAX120v2 Drops wifi and lan connection
I’ve been noticing the router out of the blue drops all wifi and lan connections and in about 1minute come back online. Both the guest and non guest wifi go away. The problem seemed to start after a c...
Simon95132
Dec 26, 2021Aspirant
Lease time is 10minutes. Seems pretty short
Simon95132
I was reading some posts on the pace modem in dmz mode. Att sets their lease time to 10minutes so that explains what I am seeing. It seems att prefer to keep this setting on their end. I’m not believing this is my problem.
I’m baffled. What else can I do to better diagnose the problem when it happens?
- plemansDec 26, 2021Guru - Experienced User
If you connect the orbi to the att device in access point mode, do you still get the issue?
- Simon95132Dec 26, 2021AspirantRunning AP is not an option for me. Has it solved someone else’s similar problem to mine? My wifi drops connection and so does lan. It’s doesn’t smell like ISP or pace issue…
- FURRYe38Dec 26, 2021Guru - Experienced User
Historical posts about PACE:
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-message
