Jimmy_W
Mar 19, 2021Guide
RAX200 DHCP drops connection for all clients
For some reason when DHCP renew happens on one device in my network it slows down all the other clients connected, even so much that it stops resolving sites or disconnect the clients from the servic...
antinode
Mar 19, 2021Guru
> Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Firmware version? Connected to what?
> [...] when DHCP renew happens on one device in my network [...]
What is that "one device"?
If the (DHCP server on the) router is granting some device the same
IP address three times in two minutes, then I'd guess that that device
is sending three address requests in two minutes, and I'd wonder why
that device would do that. And what other strange things it might also
be doing.
Why blame the router, and not the "one device"?
> I have even assigned adress reservation and it still does DHCP for the
> device.
Address Reservation is a DHCP feature, not a replacement for DHCP.
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address.
> I even blocked the device now and still it asks for DHCP and still
> says as attached device.
Did you restart the router? I wouldn't bet that "blocking the
device" would disconnect a connected device.
