chadnseng's avatar
chadnseng
RAX200 displays "Invalid IP Address. Please Change it"
Today experienced loss of wifi connection to Internet. Looked in router and found WPA/WPA2 encryption had been enabled on the router.   When I disabled it, and tried to apply I got "Invalid IP Addr...
  • chadnseng's avatar
    chadnseng
    Feb 05, 2020
    Fortunately I was able to find the solution.
    The "Nighthawk Mobile App" overwrote security settings and applied the Wireless security. It also let me restore all three radios as needed.
    I still do not know where the Invalid IP Address error came into play.
    Solution: If you find errors similar to the 'Invalid IP Address" error, I recommend trying the mobile App.
