trialcritic
May 06, 2021Guide
RAX200 download speed slow
I moved from an X10 router to a new RAX200. I have a 1150v modem. When I had the X10, I got a speed of 935 mbps. My ISP plan has a download speed of 1200 mbps. After the setup to RAX200,...
May 14, 2021Guru - Experienced User
what website are you testing on?
Did you try different servers? Some can't max out gigabit speeds
trialcritic
May 14, 2021Guide
I tried 4 speed sites
- speedtest.net (with multiple servers)
- speedtest.xfinity.com
- speedtest.googlefiber.net
- speedof.me
I also tried the tests at different time of day on multiple days to prevent unusual cases.
- plemansMay 15, 2021Guru - Experienced User
Have you tried downgrading the firmware a verison, factory resetting and doing a clean install (not from backup).
Test it with its defaults and see how it does
