Synomenon
Apr 27, 2020Star
RAX200 "Wings" don't click or snap into place?
Do the RAX200's "wings" really not snap or click into place? They seem to just sit there, unsecured. I followed the graphic on the stickers found on the wings.
RajaDaja
Apr 29, 2020Luminary
Gently push down on each wing, this should lock it in place.
Synomenon
Apr 29, 2020Star
As mentioned above, I did push down on the wings. They do not "lock" into place. After watching some video unboxings and reviews, this seems to be normal for the RAX200 which is disgraceful for such an expensive router.
- RajaDajaApr 29, 2020LuminaryNot the norm. Mine work as they should.
- SynomenonApr 29, 2020Star
Ok, maybe YOURS is. Go look at some unboxing videos and video reviews.
- japierceMay 12, 2020Guide
I just bought this router (RAX200)
the wings fold into place then you push them down to lock them?
I hear no click whatsoever, in fact, there is a tiny 2mm gap around the wings when they are fully 'seated' which makes this look sloppy. I can see thru where the wings are supposed to meet the router body.
Can someone anyone confirm they are supposed to click in and lock? (or at least sit flush with the body?) $600 for this thing, it looks rather sloppy, is that a warranty item?
