jdr2022
Apr 27, 2022Aspirant
Re: Rax200
I actually have the same question. I can't find in the general UI and assume it's fixed in RAX200 but wanted to know if there is anther way to change the duration. Why? in my case I have 65+ devic...
Apr 28, 2022Guru - Experienced User
What happens if you set up IP address reservations for some of these devices ON the router?
I recommend setting a STATIC IP address ON NAS or devices, that's out side of the routers default IP address pool, that don't need much or any router management.
