Cru26
Jan 17, 2024Aspirant
RAX35v2 - Firmware v1.0.16.132 - Internet Download/Upload Speed by Device stats not refreshing
Since the upgrade to the latest firmware, I'm observing that I'm having issues with the data in the Attached Devices view refreshing properly. It appears to be retaining the max values for Internet D...
Jul 31, 2025Guru - Experienced User
ISP Modem could play a part in some of this. Why we ask. Hard to troubleshoot more with out it.
Do you see same speed results with a eithernet connected PC behind the router? Using Ooklas installable speed test app?
Other than this speed UI issue, does the Router work?
That was 2024, maybe need a FR since you updated to check this.
Cru26
Jul 31, 2025Aspirant
I have a wireless ISP, so my WAN interface is connected to directly to their radio- no router. I see similar speed test results no matter what I use. The device that I shared in the screen capture was connected via ethernet.
Router works fine other than this specific UI issue. I tried the FR after you suggested it- it didn't fix the issue then, so why would it fix it now after multiple firmware updates?
