rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
WilsonNWT
May 13, 2020Aspirant
Finally my problem is solved by pressing factory reset (using a needle) over A MINUTE. Pressing for one second just reboot the router but pressing as long as possible (i guess i have pressed it over a minute) will actually reset to default.
Hope this helps. Good luck.
Tofu-Golem
Mar 10, 2021Apprentice
WilsonNWT wrote:Finally my problem is solved by pressing factory reset (using a needle) over A MINUTE. Pressing for one second just reboot the router but pressing as long as possible (i guess i have pressed it over a minute) will actually reset to default.
Seven seconds. You only need to hold the reset button for 7 seconds to do a factory reset.
