Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
ronald_fr
Jun 29, 2020Luminary
Hello,
I'll not be able to give you all steps ... prefering speaking FRENCH...
But if you go inside manual : https://www.downloads.netgear.com/files/GDC/RAX40/RAX40_UM_EN.pdf
Page 89 you'll find howto manually upload f/v=w
BR
Ron
Indrajit
Jun 29, 2020Guide
Hi Ron,
Thanks for helping me out, I still could not resolve the issue. In the process, it's showing it's not connected to the internet, it did not work with the MAC address of the router, I tried with another MAC address from my Linksys router, that did not work either. Linksys router working fine, no issues at all. Any thoughts, what I should do, thanks.
Indrajit
- Gioel_AssecondiJun 30, 2020Tutor
I add myself to the list of users who can't connect the EAX20 to the RAX20 with firmware 1.3.80.
Even disabling all the parameters proposed above the result does not change, the router is only a little more stable.
Workaround? Downgrade to the previous firmware version and block automatic updates.The fact that they didn't even test their devices before releasing a firmware version is quite depressing.
How sad.
