Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
scott2003lhs
Jul 02, 2020Star
For myself I had the same drop and disconnects on the older firmware. I suspect DHCP authentication issues when a device tries to reconnect after being off or away. It tries to assign the old IP to it, fails, and gives is a 169.xxx etc address, which means authentication failure. I’m not a network engineer, but DHCP service should be one of the first things you get right. Hope they find fixes... soon
ronald_fr
Jul 06, 2020Luminary
Hello,
I'd like to know wth is this bad firmware always available (download or upgrade by router) ?
Should be removed !
BR
Ron
