Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Sep 22, 2020Apprentice
Hi all,
Just for you to know. I had to do 2 power cycles in 2 days with the beta FW.
Will roll back to the .0.64 version.
Hope Netgear will find out quickly a solution....
ronald_fr
Sep 22, 2020Luminary
Hi,
My RAX40 has been exchanged last 2nd trim and Hardware Version is R1.05
It's using beta f irmware : Firmware Version V1.0.3.83_1.0.2 running fine; I don't use smart-connect as I don't wnat to reconfigure devices...
Unable to share the f/w as it's given with restrictions... I obtain it after escalation to the support.
Best regards
R
- benoit_frSep 22, 2020Apprentice
ronald_fr wrote:Hi,
Best regards
R
>> sorry, don't understand what do you mean by reconfiguring the devices ? If you are using the mixed mode (WPA2/WPA3) it (should) work without new conf on the device side
- jaf2020Sep 24, 2020Aspirant
Update here. To recap, I did the router exchange and received the refurbished router last Wednesday. The refurbished router also drops the signal 1-2x per day requiring a full restart. It's running the 1.0.3.80 firmware. I have since swapped it out to an older router I had in storage and will not be purchasing a netgear product in the near term.
- ronald_frSep 25, 2020Luminary
Hello
about : >> sorry, don't understand what do you mean by reconfiguring the devices ? If you are using the mixed mode (WPA2/WPA3) it (should) work without new conf on the device side
I try to better explain: as before f/w 80 there wasn't smartconnect available, so 2.4 & 5 GHz Wifi didn't have same SSID.
As I have devices using 2.4 and others 5 GHz I don't want to change SSID on the 5 GHz ones with the RAX40 having to choose the right one...
I use the mixed mode (WPA2/WPA3) w/o any issue.
Best regards
R
