Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Sep 22, 2020Apprentice
ronald_fr wrote:Hi,
My RAX40 has been exchanged last 2nd trim and Hardware Version is R1.05
It's using beta f irmware : Firmware Version V1.0.3.83_1.0.2 running fine; I don't use smart-connect as I don't wnat to reconfigure devices...
Unable to share the f/w as it's given with restrictions... I obtain it after escalation to the support.
Best regards
R
>> sorry, don't understand what do you mean by reconfiguring the devices ? If you are using the mixed mode (WPA2/WPA3) it (should) work without new conf on the device side
ronald_fr
Sep 25, 2020Luminary
Hello
about : >> sorry, don't understand what do you mean by reconfiguring the devices ? If you are using the mixed mode (WPA2/WPA3) it (should) work without new conf on the device side
I try to better explain: as before f/w 80 there wasn't smartconnect available, so 2.4 & 5 GHz Wifi didn't have same SSID.
As I have devices using 2.4 and others 5 GHz I don't want to change SSID on the 5 GHz ones with the RAX40 having to choose the right one...
I use the mixed mode (WPA2/WPA3) w/o any issue.
Best regards
R
