Hellman
Apr 13, 2022Tutor
RAX50: Random internet connection
This router is strange. Phones connect without any problem. My PC laptop can connect but only to the 5G. My PS5 doesn’t connect at all anymore. It did before. My Nighhawk-app can’t connect to the rout...
Apr 14, 2022Guru - Experienced User
And we still don't know what firmware version you're on or what modem/gateway your connected to
Hellman
Apr 17, 2022Tutor
My firmware version is 1.0.10.110_2.0.75.
The modem is PLANET tech. It’s fiber so it says “gigabit Ethernet converter 10/100/1000base-t to 100/1000 base-x”.
I know switched the Ethernet cable to the port that says “Internet”. I re-did the setup-process and know the Internet light is on but I can’t connect with my phone or anything. It says I don’t have internet connection.
- HellmanApr 17, 2022TutorNow everything is working including my PS5 except the Nighhawk-app? I re-installed it but it can’t detect my router even though I’m logged in on the Wi-Fi.
- plemansApr 17, 2022Guru - Experienced User
don't trust the app. Its had issues lately.
What model gateway is it? you gave me the manufacturer.
