PDWhite
Feb 12, 2020Apprentice
RAX80 5 Ghz band... Bug preventing the 5Ghz band from running at full speed
After a long, diligent and frustrating effort to get Netgear Support to resolve a problem with my original RAX80, they finally sent a replacement. The new unit does not have the slowdown problem of t...
owlpower
Feb 17, 2020Initiate
I just got a RAX80 today, and I have been load testing it. I have had no connectivity issues at all with 15+ devices connected.
However, I noticed a detail in your post. I was getting inconsistent and very poor download speeds on 5GHz. They were always below 100 Mbps and sometime like half that amount. I set the Mode from 4800 down to 2400 Mbps and I am consistently getting way faster speeds on wireless download speeds.
Thanks!
PDWhite
Feb 17, 2020Apprentice
Owlpower,
Very interesting. In my case, I did get very good performance with the 5 Ghz band, until I changed the SSID to something other than the default NETGEAR75-5G. After the change, the 5 Ghz would connect with anything. Also, a Wi-Fi monitoring utility would show 5G appear and disappear until I changed the speed to "up to 2400 Mbps." - Obviously there is a problem with the 5G band and 4800 Mbps. Sounds to me like this may be partially a problem with the code that applies the settings from the 5G Wi-Fi settings menu to the config. The firmware ste to its RESET 'default', more or less works correctly because isn't actually affected by the page's configuration code. If I make too many changes back, the only way I can get it working is to do a full hard reset.
Presently, I am awaiting a replacement for my RAX80. Sometimes it is very difficult to determine whether the problem lies in the hardware or software, which is firmware in this case. When the new one arrives, I will be able to report on whether the problem is the same on the new one. Up 'til now, the conclusion is that it is defective hardware on the current one.
