jayens
Jul 03, 2020Aspirant
RAX80 and Synology ds120j NAS unable to connect
Synology NAS server works fine when connected to other routers but only gives an orange light when first connecting via ethernet and then acts as if its not connected, LAN light on device stops blink...
jayens
Jul 04, 2020Aspirant
It’s set to DHCP after trying static IP config, no luck. Thought there might be a configuration issue with aggregation so moved to port 3, same issue. I’ve tried rebooting and everything mentioned, the NAS works fine when directly connected to PC via Ethernet.
Running 1.0.3.88 on RAX80 and and DSM 6.2.3.
jayens
I receive an orange flashing “handshake” on port 3 of the RAX30 when initially booting the NAS, it turns off a few seconds prior to the Synology beep.
- rinthosJul 04, 2020Luminary
Ok can you share what the IP address is expected to be for the NAS or is it completely empty / set to receive via DHCP?
What's the IP (local/LAN) if your Router?
What's the DHCP range for your Router?
Any allow or block list settings on your router? DHCP Reservations under Setup -> LAN ?
