daweidu
Jul 31, 2020Star
RAX80 Firmware Version 1.0.3.98
Now I can't login my router any more. It said wrong password.
Jul 31, 2020Guru - Experienced User
Have you tried the password recovery option?
daweidu
Jul 31, 2020Star
404 Not Found
The resource you have requested is not available.
Do you have a rax80 to test?
- daweiduJul 31, 2020Star
so you need to enable password recovery feature before?
my question is why they break the password in the first place.
Improves the CE-DFS behavior.
now it is crazy enough just show part of http://192.168.1.1/start.htm
crazy netgear qa. I really do not believe they do any testing.
- Jaydawgx7Aug 05, 2020Tutor
I updated my router to this firmware the other day. Since then, ALL of my wireless devices disconnected over night each night requiring a reboot of the router. Also can no longer even get to the login.. When I navigate to the routers IP (192.168.0.1), the page doesn't load with ERR_EMPTY_RESPONSE (and yes, IP is .0.1 rather than .1.1). This is already my second RAX80 as I had the first one replaced for the same issues on the previous firmware. This one was fine for two weeks until this latest update came out. I think I'll be returning this 2nd attempt at this garbage and leaving netgear. I'm not going to reboot my router every day to have internet and be able to use my smart light switches... Tempted to roll back the firmware, but it's not seeming worth it (if i can ever even get to the login)
