WenLu's avatar
WenLu
Tutor
Aug 18, 2020
RAX80 made in Vietnam has no fan inside?
I bought a RAX80 router which is made in Vietnam, and there is no fan inside, It manfactured in 2020 June.  Just want to make sure that do Netgear remove the fan from New RAX80? Thanks.
  • jcax's avatar
    jcax
    Aug 27, 2020
    WenLu:
    I asked the same question last month, was also told it has a fan, and was told to return it as defective if no fan. The device was purchased in July and was made in Vietnam.
    I returned it, got a replacement, and exactly like the first unit, it too does not appear to have a fan.
    From that I have now assumed that 1) either the fan is no longer placed right under the top grill, is really small and is out of sight within the unit, and NEVER runs, or, 2) there has been a design change and there is no fan.
    I have had no hardware-related issues with the device, so I'm sticking with it.
    Cheers.
