SAM_the_GAM
Dec 13, 2019Luminary
RAX80 New Firmware Released 1.0.1.70
I just manually checked for new firmware version and 1.0.1.70 was available. I just updated from 1.0.1.56 which seemed the most stable for me with no lan / wan disconnections. The prior version 1.0.1...
cliff344
Jan 01, 2020Apprentice
Well I pulled the router out of the box, and hooked it up real quick to pull the log file out of it. However it seemed to have lost the past logs I described previous. however, Just booting the router up onto a spare computer and pulling the log entry of most recent moments seems rather interesting. I am by no means somone to write code or play with linux software. I know enough to be dangerous. However the current log entry seems a bit suspicious being that the current time here is 8:10pm EST. I have attached a screenshot ofthe entry. not sure how you will be able to see it. note the current time and the log times. something is definately going on here.
PDWhite
Jan 02, 2020Apprentice
Since I installed my RAX80 a bit over a week ago, I haven't lost my internet connection until last night. I had a USB stick plugged into the back of the router so we could watch a video written on it on our TV via DLNA. The video playback worked fine, but that's where things got interesting.
To remove a USB stick without damaging the device, it requires going into the router's ReadySHARE page and clicking on Safely Remove USB Device. After a short interval, a message came up saying it was safe to remove the memory stick. I removed it and what happened immediately after that was unexpected.
The RAX80 stopped talking to the internet. Since I was still connected to it, I clicked on Reboot, and the reboot sequence started. When it came back up, it still wasn't talking to the internet, but it still reported Internet Status: Good. I rebooted again; no change. Finally, I walked over to the box, powered it off and disconnected to power connector for about half a minute. After powering on, the network came up correctly.
That is, except for the log. This contained the line "Wednesday, Dec 31,1969 16:00:00" over and over again about 20 times. When I checked, the NTP was changed from (US) Central Time back to the default Pacific Time. Looking through the other config settings I had set up, all of them were still there. (Except in Attached Devices, but that's another situation...) - I'm hoping that I don't encounter another hardware lockup like that. (And I'm still waiting for a reply from Tech Support on that 'another' situation.)
Happy New Year
