Clovers
Jul 09, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
ubedawg
Nov 17, 2020Star
Unfortunately keeping XB on wifi doesn't work for me neither. With ethernet, I get booted from the game completely. What I've noticed on wifi is that I get an in game message that there appears to be a problem with my network, and I get booted out of the activity, but not out of the game. If you're in a fireteam whether it's PVE or PVP, that's gonna be pretty bad. And in the game I play, if you are in PVP and leave, you are penalized. First it's a warning, the second time you get a temporary ban from the activity.
GabboCH
Nov 17, 2020Apprentice
I have both problems.
LAN disconnects when I hardwired the Xbox via Ethernet.
Dropped/Frozen WiFi connection when using mobiles/tv/smart devices.
I have the RAX80 configured as an Access Point.
This device is just garbage...
Its been more than a year without even an attempt from Netgear to fix.
I put a netgear EX8000 in the exact same place in my network with the exact same network settings/SSID and it works flawlessly.
No disconnects, reliable Wi-Fi connection.
Its 1000% an issue with the RAX80 but obviously Netgear don't care as you've already paid them 300$
- ChocobofarmNov 18, 2020GuideIt sucks if your RAX80 is dropping clients on wifi too. I guess I can consider myself lucky that mine's wifi isn't having any problems.
