Darnskippy
May 28, 2024Aspirant
Re: RAXE Access Control Issues
I initially thought my router had a flash/ram corruption problem, but now i see you're having the exact same issue i am. Garbled characters and extremely slow loading of this UI section.. Anything t...
Darnskippy
May 30, 2024Aspirant
thanks for the reply:
yes, 90 days is long past..
appreciate the note about the smart plug.. not sure i want to hard power cycle it like that tho.. and i agree with the cell notifications caused in the middle of the night would be unwelcomed..
I just checked and the CPU usage on the three is still ~1% Ive never noticed a 4th CPU.. but i never knew to look for it either so i cant say i was paying attention to it. I'll try a power cycle and see if it appears..
Thanks!
Darnskippy
Power-cycled and still only 3 CPU's.. ill try a full factory reset again and see if the 4th is there before i restore a backup. cross your fingers.. any other ideas to get the 4th CPU back are welcome...
