Darnskippy
May 28, 2024Aspirant
Re: RAXE Access Control Issues
I initially thought my router had a flash/ram corruption problem, but now i see you're having the exact same issue i am. Garbled characters and extremely slow loading of this UI section.. Anything t...
Jun 06, 2024Guru - Experienced User
Any progress on this?
Darnskippy wrote:
I initially thought my router had a flash/ram corruption problem, but now i see you're having the exact same issue i am. Garbled characters and extremely slow loading of this UI section.. Anything that accesses the Approved MAC list, i.e. QoS is also an issue. Even simply refreshing the screen takes an extended amount of time compared to other screens. now I'm also noticing that as the UpTime increases the problem gets worse. I noticed that the Memory usage begins to max out until a reboot of the device. I'm not able to locate an automatic scheduled restart option that could potentially help with an automated weekly restart.
I have about 30-35 devices online at a time (includes many IoT low bandwidth items). Approximately 50 more on the approved/offline list. Only 6 of which have static IP's reserved. I started noticing the problem back when i only had about 30 total devices. Simply refreshing to see a new device caused corrupt characters.
I wish this could be improved. This is quite a nice router, but I'm so frustrated with it I'm strongly considering a change in vendors.
- DarnskippyJun 07, 2024Aspirant
I didn't get a chance to try firmware reinstall before leaving for vacation. Didn't want to leave problems for the house sitter either... ill continue work on it when i get back to the home office.
- FURRYe38Jun 07, 2024Guru - Experienced User
đ
