TVLN753
Oct 29, 2022Tutor
RAXE290 constantly drop different clients
RAXE290 constantly drop different clients Usually it looks like the following in the logs: [DHCP IP: (192.168.1.28)] to MAC address (my PC), Saturday, October 29, 2022 09:55:30 [WLAN access reject...
TVLN753
Dec 02, 2022Tutor
I turned Armor off day 2. Unfortunately no luck.
Wxman38
Dec 03, 2022Guide
I'm still suspicious of Armor being the problem. All of my connection problems go away simply by restarting the router. Every program such as iTunes, Macruim Reflect all get internet connections for a short time after the router is turned off and restarted. Also a URL tvtango.com begins to work. Then after a period of time which I've yet to determine these sites and programs suddenly have restrictions placed on them.
When I first set up the RAXE290, I did it manually and indicated I didn't want Armor activated. Occasionally after restarting the router I would still see the popup asking did I want to activate Armor. It wasn't until by accident after I used my browser to logon to the router that instead of going to the Advanced tab, I looked at the Basic tab and there it indicated that Armor was enabled. I never enabled it! This was something that Netgear did in some manner. So I had to add the Nighthawk app to my iPhone where when I went to settings and then security I was able to turn off the button that 'enabled' Armor. Now in the Basic settings on the router it displays that Armor is not enabled. However, if I go back to the Nighthawk app on the iPhone, the button still shows that Armor is off, but at the bottom of that page is a green checkmark that Armor is 'activated'. So I think this is still the problem that after some period of time after the reboot Armor actually starts operating again. The real solution needs to be how do you completely eliminate Armor either from the router, or from some Netgear server that is activating Armor.
If someone can tell us how to completely eliminate Armor then we should be back in business.
