Wxman38
Nov 18, 2022Guide
RAXE290
When using Firefox browser if https isn't used in the search, the router doesn't seem to pass the request. Also iTunes software will not connect to the Apple server unless the router is rebooted. T...
microchip8
Nov 25, 2022Master
Have you done a factory reset of the firmware and configure from scratch manually? If not, try it.
If the problem persists, you can always roll back to a previous firmware that used to work.
Wxman38
Nov 25, 2022Guide
Unfortunately, these problems have persisted ever since I changed my old Netgear router for the new RAXE290. So there is no old firmware to rollback to at least as I understand it. Previous router was an RAX75.
