Wxman38
Nov 18, 2022Guide
RAXE290
When using Firefox browser if https isn't used in the search, the router doesn't seem to pass the request. Also iTunes software will not connect to the Apple server unless the router is rebooted. T...
Nov 18, 2022Guru - Experienced User
Does same thing happen if you disable Access Controls?
Wxman38
Dec 15, 2022Guide
Finally talked to the tiger team at Netgear. Found out the problem was a setting on the router that controlled the blocking of sites using keywords. Set that to 'never' and all of the connection problems were solved.
