wildwestman
Aug 17, 2022Guide
RAXE300 slow ReadySHARE USB SSD speeds
Hello, just got the RAXE300 and generally i think that it is a great router and i like the WiFi 6E speeds. My PC is connected to the router (Intel AX210) with 2402/1922 (Mbps) speeds which is nic...
wildwestman
Aug 17, 2022Guide
It is formatted with NTFS. I have tried with two different devices (SSD and HDD), with no change. With both USB devices I get above 60mb/s on the old XR500.
CD_router_888
Aug 23, 2022Guide
Hi wildwestman CallPaul ,
Did you use a Type C to USB 3.0/2.0 adapter HDD or just use a Type C HDD ?
