martyr444
May 04, 2021Apprentice
RAXE500 cannot get speeds over 1G even though I have 1.2G Internet
My Xfinity speeds just went up from 1G to 1.2GB. If I test my speeds hooked up to the RAXE500 Router it still only gives me the 1G. If I go straight to my Netgear CM2000 Modem I get the 1.2G. Plus my...
Razor512
May 29, 2021Prodigy
For the 2.5GbE port, if using a longer Cat 5e cable, then in your Ethernet adapter settings in device manager, and disable options such as "Green Ethernet", energy efficient Ethernet, and other similar functions.
or if you have any reliability issues, then disable those options, which will improve SNR on the Ethernet cable.
Most of those green functions attempt to save extremely tiny amounts of power by using timings to estimate the length of the Ethernet cable, and then reducing the output to lower levels to save power. The issue is that if any aspect of the cable is not up to standard for 2.5 GbE, or if it is a cable that advertises a spec but lacks proper shielding, will end up with a bad SNR which can cause reliability issues.
martyr444
May 29, 2021Apprentice
All of my Cables are Cat 7 and 6ft or less. I always set my settings to max power and disable all power save modes. That 2.5G Port is just defective.
- Razor512May 29, 2021Prodigy
The standard power saving mode in terms of windows power management for the adapter is different from functions such as EEE, Green Ethernet and other 802.3az type functionality. Basically when below a certain length, (usually 50 meters), they go into their short reach mode and start cutting back on the power used to send frames. Sadly many switches and newer routers also support these functions and in turn will use it if enabled.
PS when terminating Cat7, make sure the braided outer shielding has some length left in tact for the grounding, and make sure the untwisted segment of the cable from the termination process is kept as short as possible, this is especially important if any green functions are on, since it bases everything on estimated length and simply assumes a near perfect conductor.
Also with solid core copper wire, if frequently moving them around, they will start to fail and cause many frame issues as compared to a cable with more flexible stranded copper.
