ABONE
Jul 09, 2021Aspirant
RAXE500 QOS Settings Missing
Back On 2021-04-06 16:27:45 on Case Number 44416487 I chated with a Netgear Support Engineer and helped me find the QOS setting for the RAXE500 / AXE11000 WiFi Router. They were not in the usual pla...
IllWillTaboo
Jan 28, 2022Aspirant
Thanks for the extensive response. V1.0.9.72_2.0.36 is loaded, and I've had the gateway (Model:DPC3941B Vendor:Cisco) in bridge mode since my first attmept. I just can't get it to work in QoS. Even setting certain machines to Highest priority doesn't work. I'll set a workstation to Highest and click Apply and it just sets back to High. Moot point though as it isn't working anyway. I really apreciate the help. Tomorrow I'll try setting it up as an AP and if that doesn't work, I guess I'll head back to microcenter.
avtella
Jan 30, 2022Prodigy
QoS was removed from the latest.78 beta until it could be fixed.
