Federico-Venier
Nov 16, 2022Aspirant
RAXE500: should I buy or does it keep disconnecting from Internet?
if it is known to be buggy, I prefer not to buy to then return to Amazon. PLEASE HINTS My current D7000 (=R7000+Modem) FW V1.0.1.84_1.0.1 connected to an external modem at 1Gb/s, keeps disconnec...
Nov 16, 2022Guru - Experienced User
Try bridging the D7000 modem to put it in modem only mode.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Federico-Venier
I need to use it as a router, and "router only" is not available
LAN should be good. Anyway even disconnecting and reconnecting does not fix it.
What's your feeling for the RAXE500? I have a 1Gb/s fiber connection and about 15-20 devices
