Richard1864
Aug 07, 2019Luminary
Routerlogin.net digital certificate expired
Just discovered that the digital certificate for routerlogin.net has expired; it expired on August 2, 2019, and apparently no one at Netgear noticed it or fixed it yet that is why browsers like Chro...
shamrockshake
Sep 23, 2019Tutor
I purchased the RAX120 Nighthawk on August 8, 2019. I have not been able to login to www.routerlogin.net yet! I keep getting: Routerlogin.net digital certificate expired. This is VERY upsetting. I installed the Nighthawk app on my Samsung phone and it will not accept the network key code. So how am I supposed to update or view anything if nothing works?
Richard1864
Sep 23, 2019Luminary
FCC has confirmed all supported Netgear routers, consumer and business, are affected by this expired certificate, that the issue has been raised with Netgear, and they don’t know if Netgear will ever fix it. The FCC claps confirmed this expired certificate affects accessing https websites and apps, and prevents even simple router maintenance as administrators can no longer login to the routers. The FCC no longer recommends purchasing Netgear routers because of this outstanding critical issue.
It would be really nice if Netgear would finally actually REPLACE the expired certificate. Even the FCC says this should have been done within 12 HOURS of it first being reported and emergency firmware updates pushed out to all supported routers within 24 hours of first report.
- MaltySep 24, 2019AspirantTried signing into nighthawk app tonight and I keep getting an error try again. So I guess I’m not going to get signed in. So what do we do now
- shamrockshakeSep 24, 2019Tutor
Thank you for that information. As I have been reading tonight online, I see this is a huge problem. I don't understand why they haven't taken steps to correct it. Buying the lastest router, one think they knew people would learn their certificate is expired. Mine is new enough we can return it. I am going back to my old one for now. I have always liked Netgear, but this has sure put some antenna's up for me concerning future purchases.
I must have tried 50 times to sign in. One time it would take my information, the next time it acted like I had the wrong password. I did everything one usually does when things like that happen, to no avail. Even on my phone app, the password wouldn't work the second time I signed in. I couldn't figure that one out since nothing had changed since hooking up the router. I even tried changing browsers as suggested by Netgear help via email. I think I got level one help because it was no help at all. I'm going to use my old router for now and read up on other brands.
