bmpierce84
Oct 12, 2026Aspirant
Trying to update firmware & getting error, no matter what firmware version I use
I'm having the same issue with my RAX43v2, trying to update firmware & getting error, no matter what firware version I use. I've factory reset. Plugged directly in to LAN port. Currently running V1.1...
Oct 14, 2026Guru - Experienced User
What error are you getting?
Are you extracting the firmware prior to uploading it? many just download it and then try to upload it to the router but it needs to be extracted.
- bmpierce84Oct 20, 2026Aspirant
Failure
The firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
I just extracted the .chk file from the zip file and attempted to upload from the link you sent, but this same error message happens no matter how I try to upload any version manually or if I try the check for firmware update, it goes through to text a new version and I tell it yes to update and then it says downloading and then just gives a short message firmware is invalid
- plemansOct 22, 2026Guru - Experienced User
there's been a couple posts from the version of firmware you're on (here's one:
Welcome to the NETGEAR Community | NETGEAR Communities
Some users were able to downgrade to an older version and then upgrade to the latest one with success. I'd try that first.
