pjackel
Jun 23, 2020Tutor
Using SmartConnect on Nighthawk RAX80
In re using SmartConnect on the Nighthawk RAX80: If the original name of my 5G network is not the same as that of my 2G network, will devices that are already "attached" to the original 5G network au...
- Jun 23, 2020
No.
If you're original name was***** for the 2g and ******5g for the 5g and you turned on smart connect and it just went to ***** that was the name of the 2g
then you'd need to go into the devices connected to the 5g and reassociate them to the new ssid.
