April1
Dec 24, 2019Guide
WiFi 5G dropping on RAX80
I got a new AX8 router, updated FW to the latest, rest to factory status, QOS disabled, AX enabled, set 5G channel to 161 and also tried 36, noticed two issues: 1. Fan is noisy 2. 5G radio drops aft...
Fcooper
Sep 22, 2020Aspirant
Having the same 5GHZ drop problem. Will NETGEAR deal with it? Router to expensive for these type of problems to continue to exist.🤬
- brucescarDec 02, 2020Aspirant
Same issue on RAX48, doesn't look like there's any solution. I should just return this.
- Ferjy_FangleMar 22, 2021Aspirant
Having the same problem with my RAX45.
- GabboCHMar 22, 2021ApprenticeJust take it back and buy something else.
Ive been waiting 18 months for a fix but not even 1 attempt to fix it from Netgear.
