Th3Alchemist
Jun 08, 2020Aspirant
WiFi connection Unstable
I just got this new Router. Freshly installed and upgrade to the latest firmware (Firmwareversion V1.0.3.80_1.0.1). I've manually chosen a wireless channel that wouldn't interfere with the one if my ...
Scottish
Jun 08, 2020Tutor
So that I understand 10.0.0.7 is being assined across two different MACs ? Check that...7 isn't static on a client and within the DHCP scope. If so reduce the scope or set the client to DHCP assigned.
but mostly just a guess as the logs don't show much.
Th3Alchemist
Sorry I wasn't more specific;
This is just small fraction of the log. It extends to a lot more. I have around 6 different wifi clients. All get the same problem. Some connected via 2.4GHz, other 5GHz.
Later I will backup my settings and restore to factory defaults.
