Th3Alchemist
Jun 08, 2020Aspirant
WiFi connection Unstable
I just got this new Router. Freshly installed and upgrade to the latest firmware (Firmwareversion V1.0.3.80_1.0.1). I've manually chosen a wireless channel that wouldn't interfere with the one if my ...
Scottish
Jun 08, 2020Tutor
So that I understand 10.0.0.7 is being assined across two different MACs ? Check that...7 isn't static on a client and within the DHCP scope. If so reduce the scope or set the client to DHCP assigned.
but mostly just a guess as the logs don't show much.
Th3Alchemist
Also to answer your question, each MAC Address is being assigned it's own IP address (always the same IP).
- ScottishJun 08, 2020TutorHmm might work. Sounds like the dhcp setup. other thing I’ve seen in the past is firewall blocking the incoming final dhcp ack request which is on a different udp port rather than the broadcast discovery messages.
Hope you get it fixed.- Th3AlchemistJun 09, 2020Aspirant
Unfortunately the issue persists. I only changed the SSID name and Password. The rest is pretty much default.
[DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:41:25 [DHCP IP: 192.168.1.7] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:37:02 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:24:23 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:23:00 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:22:47 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:22:33 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:22:17 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:22:03 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:22:01 [DHCP IP: 192.168.1.5] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:21:26 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:21:07 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:20:54 [DHCP IP: 192.168.1.4] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:20:47 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:20:37 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:20:18 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:19:56 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:19:43 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:19:29 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:19:14 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:19:08 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:18:54 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:18:36 [DHCP IP: 192.168.1.3] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:18:23 [DHCP IP: 192.168.1.5] to MAC address <hidden mac address>, Tue,Jun 09,2020 06:17:26
Not sure if this helps, but I also have a very low bandwidth speed on a notebook (15-20 Mbps on a 100 Mbps connection), while standing right next to the router. Wired works perfectly.
- ScottishJun 09, 2020Tutor
Couple of things to try
1. could you go to the ...3 client and (assume Windows) run "ioconfig /all" in a cmd and post the info. (Scrub the MACs before posting if you want)
2. Just noticed you have smart connect working. Always had issues with that feature, could you disable that and see if it works?
are those the only logs you get ? Still leaning in the DHCP lease time direction. The times differences in the logs look to me like the renewal reservations. But a massive guess
