Th3Alchemist
Jun 08, 2020Aspirant
WiFi connection Unstable
I just got this new Router. Freshly installed and upgrade to the latest firmware (Firmwareversion V1.0.3.80_1.0.1). I've manually chosen a wireless channel that wouldn't interfere with the one if my ...
Th3Alchemist
Jun 09, 2020Aspirant
I've resetted the router and the problem persisted for some time. Suddenly it stopped and hasn't returned.
I do still have an issue with the WiFi bandwidth. It seems to run very slow. In the settings I've checked that both are set on max (600 Mbps 100% on 2.4 GHz, and 2400 Mbps 100% on 5 GHz). Guest WiFi is disabled.
With an internal network speedtest (iperf to a local wired PC), I only get around 80 Mbps.
iperf3.exe -c 192.168.1.3 Connecting to host 192.168.1.3, port 5201 [ 4] local 192.168.1.8 port 51877 connected to 192.168.1.3 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.01 sec 6.75 MBytes 56.3 Mbits/sec [ 4] 1.01-2.01 sec 13.6 MBytes 114 Mbits/sec [ 4] 2.01-3.00 sec 9.00 MBytes 75.8 Mbits/sec [ 4] 3.00-4.00 sec 11.0 MBytes 92.3 Mbits/sec [ 4] 4.00-5.00 sec 5.38 MBytes 45.1 Mbits/sec [ 4] 5.00-6.00 sec 11.5 MBytes 96.1 Mbits/sec [ 4] 6.00-7.01 sec 10.1 MBytes 84.7 Mbits/sec [ 4] 7.01-8.01 sec 9.88 MBytes 82.5 Mbits/sec [ 4] 8.01-9.00 sec 8.50 MBytes 72.1 Mbits/sec [ 4] 9.00-10.00 sec 12.2 MBytes 103 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth [ 4] 0.00-10.00 sec 98.0 MBytes 82.2 Mbits/sec sender [ 4] 0.00-10.00 sec 98.0 MBytes 82.2 Mbits/sec receiver iperf Done.
Note that 192.168.1.3 is a cat6 connected PC.
I should get at least 550 which I had on my previous low-end router. I've enabled/disabled some WiFi settings (AX, Smart Connect, 20/40 Coexistence) but nothings seems give a decent WiFi speed for this "high-end" router.
Should I return it for warranty? I've made this speedtest short after I've resetted the router (minimal settings adjustments done).
mjc775
Jun 10, 2020Luminary
Is "Enable MU-MIMO" unchecked? I noticed speed issues when it was checked.
Also, in lieu of using Smart Connect, I just name my 2.4 and 5 networks the same name so that the clients can decide the best network.
I'm still on FW V1.0.1.70_1.0.30
