jstro's avatar
jstro
Windows computers won't connect to WIFI after router reset
I did a reset on my RAX70 router and everything came back online except for the windows computers on WiFi.  They won't connect to the WiFi at all. I get the "can't connect to this network" on every s...
  • jstro's avatar
    Jun 25, 2025
    Thanks for the reply. I tried those but with no luck. However I did find a solution. I did another reset and then the router worked normally. Who knows why.
