Fokash
Dec 28, 2020Aspirant
Wired connection to XR1000 slower than connection directly to modem
I have recently purchased xr1000(ax5400) and I cannot get the wired connection to the speeds that I see when connected directly to modem. I have a PC and an Xbox Series X that are connected directly ...
Fokash
Jan 01, 2021Aspirant
No its not connected to another router, its connected to the modem.
Newfiedrool
Jan 01, 2021Virtuoso
Does that modem have WiFi ?
- FokashJan 01, 2021AspirantYes , I had read somewhere in reddit when searching for a solution to try it with the modem wifi disabled.
- NewfiedroolJan 01, 2021Virtuoso
That's a router as a pure modem does not give off WiFi. You need to turn that into a modem only as you will have double Nat issues and anything connected to that will have not been controlled by the XR1000 functions.
IF you provide your isp equipment info you might get help here of pop over here and post here.
https://forum.netduma.com/forum/87-dumaos-on-netgear-nighthawk-support/
