TK44
Sep 17, 2022Aspirant
Xbox Series X keeps dropping
Just bought this router and once I set everything up, I fired up the Xbox Series X and it does this thing where it'll connect via Ethernet cable for a second and then it'll disconnect. I've tried ch...
Sep 17, 2022Guru - Experienced User
Are you using any parent controls or access controls?
Is ipv6 enabled?
