mbc1965
Mar 31, 2022Guide
Ready Share Not Connecting After New Disk
Put a new USB Drive in Ready Share and now it won't connect from Windows 11 like the old one. The Share Name box on the old drive said: \\readyshare
Using RUN, \\readyshare would open on my computers and then I'd map the network drive and share files from it.
With the new drive I did a clean format with no Drive Letter or anything else.
The new drive has: \\readyshare\T_Drive when I try to open it I get the "Network Error Windows Cannot Access..." Also tried it with just \\readyshare, same thing.
Can connect with HTTP/HTTPS, but since the Drive doesn't show on my computers I can't manage it.
Thanks in advance!
1 Reply
Hi mbc1965 ,
Which Nighthawk router do you use ?
