dshunzeker
Sep 03, 2022Aspirant
Readycloud access either with RAXE450 or R8000 AP mode under RAXE450
I have had an R8000 for years in normal mode with readycloud access. The R8000 started having internet issues. Firmware is up to date. That is only for background. I bought an RXAE450, assuming i...
dshunzeker
Sep 04, 2022Aspirant
Thanks for the reply.
Regarding have I tried it, please see the middle of my description. In AP mode, everything works that is needed, save one item: Readycloud. I can access the drive by \\ipaddress\usb_storage\ from anywhere on the network. It is not clear if AP simply disables Readycloud or if RAXE actively blocks something. That is the question. Is there a port that can be opened or some other simple fix to get access?
Regarding, "none of the USB features seem to be in there," yes, I can make all USB functions work except ReadyCloud.
Regarding the other items on the disable list, most are obvious based on AP puts the R8000 in basically a slave mode.
michaelkenward
Sep 04, 2022Guru - Experienced User
Next time use paragraphs. They are easier to read than slabs of continuous text, especially when you throw in bits like "I have tried a thousand ways and altered order of operation myriad other ways".
Did you ever get the R8000 to work with ReadyCLOUD when it was running as a router?
How are you trying to access ReadyCLOUD?
There are various options, some of which cause problems for me. The Windows app, for example, is a pain whereas going through https://readycloud.netgear.com/ or th Android app is fine.
Maybe you did all that in your myriad other ways. I can't tell.
- dshunzekerSep 04, 2022Aspirant
Regarding writing protocols, where I have broken things out in separate paragraphs, I get flamed for writing too much. I made a call.
Regarding has ReadyCloud ever worked, trying not to be too redundant, yes, in my original slab text I note that, in my current setup, I started by registering and testing Readycloud, and then setting to AP mode and rebooting. I can access the router configuration page by ip address. It shows that I am registered. I had hoped that if it held the registration it might work. Not to be.
I access Readycloud as you do, by browser. I have tried several, as they all work a bit different.
Yes, those were part of the myriad ways. I was trying to differentiate between different connected setups and different access methods.
It did occur to me a few minutes ago that Netgear messes with local DNS to be able to do things like routerlogin instead of using ipaddress to access the configuration setup. Is there a way to see and/or edit a local LAN DNS table to push readycloud requests to the AP device?
