wdreiling
Feb 13, 2020Initiate
Readyshare disconnects after about 12 hours
ReadyShare does not remain connected with my WD 4tb drive formatted with NTFS. I am able to see the drive and connect properly to begin with. Everything seems fine. After approximately 12 hours (o...
schumaku
Feb 13, 2020Guru - Experienced User
Disable the WD USB enclosure automatic power handling.
wdreiling
Thank you for the advice. I ran the WD Drive utility that came with the hard drive. There was a "Sleep" setting which I have now set to off. Is this what you were referencing?
