cminnes
Dec 13, 2021Follower
Readyshare doesn't work
I've purchased the Nighthawk RAX50 for use with a USB Drive. While I see the USB drive in Network, it is appeaing as a media device as you can see in the screen shot below. It will not let me browse ...
Delux
Dec 15, 2021Aspirant
I am having the same issue. When I log into the netgear nighthawk, I can see and I can allow the USB drives to be accessed via Advanced Settings Setup "USB Settings". However, when I move over to the readyshare tab under readycloud I cannot see the USB drives under "Available Network Folders". When I log into readycloud (after already registering the RAX120) I can see the RAX120 but NOT the drives that are connected. Any ideas?
The drives are exfat formatted and accessible without passwords via my local laptops.
michaelkenward
Dec 15, 2021Guru - Experienced User
Which one? Apps aren't always the same. Things that work in Android fall over in iOS, and vice versa.
What do things look like in the browser graphical user interface (GUI)? That's always a better way to control things than the apps.
Maybe Exfat is not be the best option. I see no sign that ReadySHARE supports it.
NTFS is the one that seems to work with anything.
Did you find this?
ReadyCLOUD FAQ | Answer | NETGEAR Support
