SlipknoT74769
Apr 02, 2020Aspirant
ReadyShare drives not playing nice with large files after update
I have used two ReadyShare drives through the routers USB ports for a Plex server and Games drive since getting this router a little over a year ago. I'm still able to see the drives from all the PCs on the network and generally they work fine, but after a recent firmware update, I'm no longer able to transfer larger files (around 1.2GB it seems, but it varies) and not able to delete certain files. I get weird errors like "Invalid file handle" or I/O errors when trying to move or delete files to or from the drive through network maps (There are files that were trasnfered to the drive fine before the update, but now are unmoveable and not able to be deleted after the update).
Using FTP seems to fix the file size transfer issue (I'm able to download a file to a computer on the network, then move it via FTP just fine) but still not able to delete certain files through FTP and get a "Permission Denied" error, but again, only on certain files.
Is there a fix for this, or does anybody have an idea of what could be going on? I'm not able to map FTP shares to a drive letter and download large files directly to the ReadyShare drives like I used to and still not able to remotely delete certain files no matter what I do. It's not a permissions/credentials issue either as I'm able to delete MOST files, just not certain ones.
Thank you for your time, and PLEASE help!
- SlipknoT74769Aspirant
So I've been reading the forums and it appears to be the newest update causing issues with files over 2GB. Can I just download the old firmware and flash that without errors and is there any downside to NOT having the latest firmware? Is Netgear going to fix this in a new update?
So I've downgraded to firmware version 1.0.5.2 and it fixed the issue.
Whatever Netgear changed from this firmware to the most recent, messed up large file transfers.
Please let me know when this issue is resolved, as I would like to be on the latest firmware for security reasons. I was an early adopter for this router, and as much as I paid for it, I would expect it to work properly! This is putting a SERIOUSLY sour taste in my mouth for buying another Netgear router in the future.- BB_FBAspirant
I have the same problem. Took al lot of time to try to solve. Did not succeed.
I could only find one strange thing.
If i connect the usb hard disk directly to my computer, go into terminal and use ls - l the file size given is good
If i connect the usb hard drive directly to my nighthawk, go into terminal and use ls -l the file size given is negative
(-rwxrwxrwx 1 USERNAME staff -510777885 DATE FILENAME)
I think this is the problem but i don't know the solution for it.
