RXC86
Oct 31, 2019Tutor
ReadySHARE inflating file to 1MB (RAX120)
When uploading a file to my ReadySHARE drive, it will inflate the file to 1,024 KB, resulting in a corrupted file. Looking in a hex editor, there is just blank data written to the end of the file. At...
- Nov 11, 2019
Hello RXC86 & ArunGupta,
Curious to know, did the issue occur when using other firmware versions? I would recommend updating to the latest FW version linked below and let me know if there are any improvements.
https://kb.netgear.com/000061295/RAX120-Firmware-Version-1-0-1-100-Hot-Fix
Christian
Christian_R
Nov 11, 2019NETGEAR Employee Retired
Christian
ArunGupta
Nov 16, 2019Apprentice
Hi Christian,
So sorry that I did not respond earlier. As you know I am working with support on the other issue. They have given me a special firmware for debugging. I just tested and the issue does not occur with that special firmware. So, it would seem that the issue could be with 1.0.0.84.
Thanks,
Arun
