meanjeanslo
Dec 18, 2024Guide
Readyshare no longer available - asking for credentials, but not supposed to
My router's Readyshare has suddenly stopped working. When I try to access it, it prompts for credentials which it should not be doing. I reset it to factory and it still isn't working. Firmware...
- Dec 18, 2024
This is what solved it for me and the video where I got the information:
Enable insecure guest login policy
Start > Run > "gpedit.msc"
Computer Configuration > Administrative Templates > Network > Lanman Workstation
Select: "Enable insecure guest logins"
Change to Enabled and Apply
close window and then try again.
This absolutely worked for me!
meanjeanslo
Dec 18, 2024Guide
